Coolant Drain Plug 2000 Dodge Stratus 2.4L
Old Sep 26, 2006 | 01:32 PM
sgamble3's Avatar
sgamble3
Default Coolant Drain Plug 2000 Dodge Stratus 2.4L
Can anyone tell me where the drain plug for the radiator is located on a 2000 dodge stratus 2.4L Engine?
Old Sep 27, 2006 | 10:28 AM
tomthedog's Avatar
tomthedog
Default RE: Coolant Drain Plug 2000 Dodge Stratus 2.4L
IF you have one (not trying to be smart) it should be facing your eng on the bottom side of the rad. otherwise you will have to pull the lower rad hose to drain. not all rads have one, cheaper to make if they don't.
are you just changing the coolant or are you having overheating probs? as long as the coolant is the right color, you might want to look some place else. let us know the deal. good luck.
