'CHECK ENGINE' ... !!!
Sometimes this automatic system is activated same without real problems in the engine, and there are no possibilities of starting again.
I remain in the road and must call the mechanic in order that he deactivates it with his equipment.
>> there is some way of deactivating it directly in the car? Can someone help me?
Stratus LX V6 1996 Location: Brazil
Best Regards from Luisitto
Usually removing the ground from the battery will remove the codes. Depending on the severity of the condition that set the check engine light, it may just come right back on. Good Luck
Great!,
thank you very much for the advice.
Now I am trying to find the fault since nothing was indicated by any code...
Seemingly there is an electrical problem in the ignition.
An embrace, Luisitto
