Bleeding ABS Brakes - 2000 Cirrus LXI
Old Oct 16, 2006 | 11:02 PM
hmorgan's Avatar
hmorgan
Default Bleeding ABS Brakes - 2000 Cirrus LXI
Does anyone know the proper process to bleed brakes on a 2000 Cirrus LXI with ABS.
The Haynes manual says you must have a DRB II hooked up on ABS equipped Cirrus/Stratus/Sebring to properly bleed the system.
I have an OBD II and Enhanced Chrylser scanner/actuator coming this week. What I don't have is the procedure for accomplishing this process using the scan tool/actuator.
Anyone out there have the factory manual with instructions for this?
Thanks for the help!
