clear corners
Old Oct 19, 2006 | 08:21 AM
liquidoxygen's Avatar
liquidoxygen
Default clear corners
hey all, wondering if anyone knows how to take out the amber color on the corner of a (2005) stratus headlight. Thanks
Old Jan 1, 2007 | 05:42 PM
sprmn1968's Avatar
sprmn1968
Default RE: clear corners
I did it with my 2000 Stratus. I took out the headlight assembly, removed the bulbs, took a pair of long nose pliers and snipped the tabs holding the amber lens in. Then Iheld the assembly so the lens was resting against the bulb hole and took a pair of wire clippers and just broke the amber lens into small pieces so they would fall thru the hole. This is a permanent way of doing it so make sure it is something you want to do unless you can figure out a way to open up the headlight assembly and take the amber lens out in one piece. Here is the result.
https://dodgeforum.com/photo.asp?pho...=6&apage=1
