Where does the oil come from?
Old Jan 15, 2007 | 02:51 PM
dave2's Avatar
dave2
Default Where does the oil come from?
Hi folks,
I have a '98 2.0 . I've been noticing some oil running down the side of the engine and onto the filter. It's had 2 head gaskets replaced with oil in the same area. Figuring it was the HG again, I just set in to wait until it gets bad enough to replace. Then, I was changing spark plugs the other day (super easy BTW), and when I pulled the #1 plug, the socket was covered with oil. Of course, the oil ran into the cylinder and smoked like hell. Could it be that I only have a problem with the valve cover or something in that area, and not a HG?
Thanks,
Dave
Old Jan 15, 2007 | 05:32 PM
Joshwfl's Avatar
Joshwfl
Default RE: Where does the oil come from?
I had the oil in the spark well problem. I replaced the valve cover gaskets and the plug seals, problem solved.
Old Jan 16, 2007 | 03:16 PM
dave2's Avatar
dave2
Thanks. Just ordered the set. Don't even want to know if I paid to have 2 HG's installed for nothing (or, if they were even installed to begin with)
Thanks, Dave
Old Jan 25, 2007 | 03:57 AM
Thequisnos's Avatar
Thequisnos
You may want to check your rear main seal also...
