96 Stratus Blows cold air
Old Jan 18, 2007 | 01:21 PM
elmco2's Avatar
elmco2
Default 96 Stratus Blows cold air
I have a 96 Stratus it blows cold air when driving but when Idling it will blow warm air.
Any ideas what the problem is and how to fix it. I live in Maine and NEED HEAT!!! lol
Old Jan 19, 2007 | 10:48 AM
superbee69's Avatar
superbee69
Default RE: 96 Stratus Blows cold air
It sounds like it's related to your coolant system.Have you noticed if your engine temp. drops when the cold air comes out of the heater? If so, yourantifreeze mix could be wrong or not enough.If the engine temp. is normalyour thermastat may be bad. These are the cheapest and quickest problems to check on.
Old Jan 19, 2007 | 10:59 AM
elmco2's Avatar
elmco2
When the car is idling it will blow warm air and the temp guage will rise slightly, when you start to drive it will drop back down to the cold psoition and blow cols air.
Old Jan 22, 2007 | 11:46 PM
detroitdieselman's Avatar
detroitdieselman
Try bleeding air from the thermostat housing, you probably have an air pocket there. First, top off the plastic bottle, them get the engine warmed up. Then, take a 10mm box end wrench and crack the bleed screw on top of the thermostat housing and let the air out till you get a steady flow of coolant. Then tighten it back down ant check the plastic bottle lever and add if nescessary.
It don`t get any cheaper or easier than that to try first.
Old Jan 26, 2007 | 02:26 PM
elmco2's Avatar
elmco2
Not to be ignorant, but where is the Thermostat located and what does it look like..I'll try anything at this point..
Thanks
