2002 stratus leaking transmission fluid
Old Jan 29, 2007 | 06:33 PM
powersm3's Avatar
powersm3
Default 2002 stratus leaking transmission fluid
I have a 2002 Stratus that is leaking transmission fluid. The weird part about it is that it is leaking the fluid from under the very front driver side. I can't seem to trace where the leak is coming from. Does anyone have any information? Do they have transmision filters that need to be replaced?
Old Jan 29, 2007 | 06:36 PM
shnormo's Avatar
shnormo
Default RE: 2002 stratus leaking transmission fluid
You could be leaking from the cooler line or the cooler itself. Yes, they do have internal filters that need to be replaced.
Old Jan 29, 2007 | 11:35 PM
Richards_Keith's Avatar
Richards_Keith
At firstit seems thatthe leak is at the pan gasket seal, but I believe the solenoid pack is a better bet.
220.00 (solenoid + labor) at Cottman Transmission. They can check it for free.
Old Jan 31, 2007 | 01:00 PM
donmjr's Avatar
donmjr
I just had a leak on my 01 fixed. It wasa seal. Labor costs were high because they had to take apart the trans to get to it.
Old Feb 3, 2007 | 03:41 AM
tomthedog's Avatar
tomthedog
if you can swing it, clean the eng/tranny of atf (after it's up to norm temp). drive it about 5-10 miles at speeds no greater than 40mph. crawl under the car and take a look. you should be able to tell ABOUT where the leak is comming from.
i once had a '78 volvo wagon auto that had a prob with the trans cooling lines (that ran to the rad) rubbing, wore a hole in one line, had to replace after the duct tape failed for the 100th time.
Old Feb 3, 2007 | 11:49 AM
2.4 DOHC Demon's Avatar
2.4 DOHC Demon
Check your Axle seal. It could be broke. The A604, has the diff cover on the drivers side as well so check those places.
