99 DODGE STRATUS SUDDENLY STOPPED AND WILL NOT RESTART
Old Mar 11, 2007 | 08:35 PM
HB1980's Avatar
HB1980
Default 99 DODGE STRATUS SUDDENLY STOPPED AND WILL NOT RESTART
I HAVE A 1999 DODGE STRATUS THAT SUDDENLY STOPED ON ME WHEN I WAS DRIVING HOME. i COULD NOT TURN IT BACK ON. I HAVE CHANGED THE FUEL PUMP. AND RAN SOME CODES. IT SHOWED THE FOLLOWING CODES: TPS, AND MAP SENSOR, I HAVE CHANGED THE TPS AND MAP SENSORS AND IT IS STILL ASKING FOR THE TPS. ANY SUGGUESTIONS????
Old Mar 11, 2007 | 10:49 PM
skierbri10's Avatar
skierbri10
Default RE: 99 DODGE STRATUS SUDDENLY STOPPED AND WILL NOT RESTART
ORIGINAL: HB1980
I am pretty sure that you have to have the TPS set up correctly. Not sure though. Obvious question, you have checked all the fuses right?
Old Mar 14, 2007 | 05:02 PM
sfx_1234's Avatar
sfx_1234
Is the motor turning over when you try to start it? The timing belt could have snapped on you. Hope thats not the case but its possible. =(
Old Mar 16, 2007 | 01:48 AM
andrewjb2003's Avatar
andrewjb2003
I think it could be the timing belt, that happend to me.
I was driving, and i see alittle bit of smoke not alot, then all the sudden the car dies, and never started, didnt feel like spending alot to fix it so i got my new stratus.
the car i had was a 97' intrepid
