2005 Viper SRT-10 Convertible Overview
2005 Dodge Viper: MSRP $81,495
(This is NOT the 2006 Viper Coupe Info)
Quick Specs
Body Styles: 2-Dr Roadster
Engines: 8.3L V10
Transmissions: 6 Speed Manual
Drivetrains: Rear Wheel Drive
2005 Dodge Viper Performance & Efficiency Standard Features
-8,285 cc 8.3 liters V 10 front engine with 102.4 mm bore, 100.6 mm stroke, 9.6 compression ratio, overhead valve and two valves per cylinder EWC
-Premium unleaded fuel 91
-Fuel economy EPA highway (mpg): 20 and EPA city (mpg): 12
-Multi-point injection fuel system
-18.5 gallon main premium unleaded fuel tank
-Power: 372 kW , 500 HP SAE @ 5,600 rpm; 525 ft lb , 712 Nm @ 4,200 rpm
2005 Dodge Viper Handling, Ride & Braking Standard Features
-Four-wheel ABS
-Four disc brakes including four ventilated discs
-Immobilizer
-Rear limited slip differential
-Wishbone front and rear suspension independent with stabilizer bar and coil springs
2005 Dodge Viper Exterior & Aerodynamics Standard Features
-Body color front and rear bumpers
-Coefficient of drag: 0.4
-Fixed hoop convertible rollover protection
-Manual softtop convertible roof with glass rear window
-Driver and passenger power body color door mirrors
-External dimensions: overall length (inches): 175.6, overall width (inches): 75.2, overall height (inches): 47.6, wheelbase (inches): 98.8, front track (inches): 61.6, rear track (inches): 60.9 and curb to curb turning circle (feet): 40.5
-Front fog lights
-Projector beam lens Bi-Xenon headlights
-Luxury trim alloy & leather on gearknob
-Black paint
-Fixed rear window with defogger
-Tinted glass on cabin
-Weights: curb weight (lbs) 3,410
-Windshield wipers with variable intermittent wipe
2005 Dodge Viper Interior Standard Features
-12v power outlet: front and 1
-Air conditioning
-Element antenna
-Peripheral anti-theft protection
-Front ashtray
-RDS audio system with AM/FM, Disc Autochanger and six-disc remote changer
-Cargo capacity: all seats in place (cu ft): 8.4
-Front seats cigar lighter
-Clock
-Full dashboard console , full floor console with covered storage box
-Courtesy lights
-Door ajar warning
-Floor covering: carpet in load area
-Driver front airbag intelligent , passenger front airbag with occupant switch off intelligent
-Sports driver and passenger seat
-3-point reel front seat belts on driver seat and passenger seat with pre-tensioners
-Front seat center armrest
-Lockable glove compartment
-Two head restraints on front seats
-Headlight control with time delay switch-off
-Height adjustable pedals
-Illuminated entry system
-Internal dimensions: front headroom (inches): 36.5, front leg room (inches): 42.4 and front shoulder room (inches): 54.1
-Low fuel level warning
-Low tire pressure indicator
-Remote power locks
-Power steering
-Front power windows with two one-touch
-Front reading lights
-Rear view mirror
-Remote control remote trunk/hatch release
-Suede seat upholstery with additional leather
-Seating: two seats
-Seven speaker(s)
-Leather covered steering wheel with tilt adjustment
-Tachometer
-Ventilation system with recirculation setting
2005 Dodge Viper SRT-10 Standard Safety Feaures
• 4-Wheel ABS
• Airbag On-Off Switch
• Child Seat Lower Anchorage
• Trunk Release
• Pretensioner
• Tire Pressure Monitor
• Energy Management Feature
More info here: http://www.geocities.com/vipergts_do...pers_Lair.html
-Matt-
Quick Specs
Engines: 8.3L V10
-Four-wheel ABS
-Immobilizer
-Front fog lights
-Black paint
-Air conditioning
-Element antenna
-Front ashtray
-Clock
-Courtesy lights
-Door ajar warning
-Remote power locks
-Power steering
-Rear view mirror
-Seating: two seats
-Seven speaker(s)
-Tachometer
• 4-Wheel ABS
• Trunk Release
• Pretensioner
-Matt-
