Aux Transmission Oil Coolers
I have a 2012 RAM SLT 4.7L 2wd and we are pulling a Jayco 26BH RV. Do the experts out there recommend that we have Dodge install an Aux oil cooler to keep the transmission from overheating?
it is all ways a good idea to install an Aux oil cooler . all so here is an external filter for your chrysler.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
