Exterior Modifications Talk about your rims, body kits, and other exterior mods here.
suspension lift kit
Old Nov 6, 2007 | 08:49 PM
kalama's Avatar
kalama
Default suspension lift kit
I have a 2001 Dodge Ram 2500 4x4 Cummins and wanted to give it a suspension lift at about 5-7 inches im new here and just wanted some input on what you guys thought would be a goodkit. i was looking at the 6" dick cepek and the 5" superlift but im not sure im open to suggestions..thanks for helping me out....
Old Nov 14, 2007 | 11:27 PM
Tractor's Avatar
Tractor
Default RE: suspension lift kit
There are so many lifts out there it is hard to choose. All I can say is do your homework. You usually get what you pay for. Think of the precious cargo you will be hauling as well as regular cargo. I have seen so many bad lifts out there it is not funny. Stay away from lift blocks in the rear that are any taller than stock. Spend the money and get new springs. I am not a fan of any lift that increases ride height without increaseing suspension travel and/or articulation. Check out KORE suspensions for dodge. If it can run the baha 1000 and finish 2nd, it has to be well engineered. Good luck, hope this helped.
