Exterior Modifications Talk about your rims, body kits, and other exterior mods here.
door adjustment, tires
Old Dec 24, 2005 | 09:37 PM
jmlcolorado's Avatar
jmlcolorado
Default door adjustment, tires
couple of questions here.
first, my drivers side door has seemed to come out of alignment.[&:] the door hits the striker bolt too low and the weather sealing has a minor gap in it. what is the easiest way to adjust the door. the door hinges? i dont want to adjust the striker bolt due to the weather stripping. do i just loosen the hinges and jack up the door to proper alignment?
second question involves tires.
i want to put oversized tires on the truck. i own a 98 ext. cab dulley. how big of tires can i install without a body lift or suspention for that matter. because it's a dulley, i wonder if i need some sort of spacer between the rims in the rear? i'm sure i can go a couple of sizes wider without the tires interferring with instalation.
any help on these topics would be much abliged.
thanks
josh
jmlcolorado@msn.com
