debadging?
Old Sep 4, 2004 | 08:31 PM
Yellow Runner's Avatar
Yellow Runner
Default debadging?
the little Dodge badges like the 1500 badge on the side and the Dodge badge on teh tailgate is it somthing simple you can do yourself or are those badges drilled into the truck? i was looking at them and noticed a piece of black foam stuff so i was thinking mabey it was jsut stuck on there with sticky stuff lol.
Old Sep 25, 2004 | 04:28 AM
BIGMOPAR's Avatar
BIGMOPAR
Default RE: debadging?
Double sided 3M foam Tape, I always use a Hair dryer to heat up the emblem be careful though you just want to warm it up not fry it! Then just get behind it with a Bondo spreader so it won't damage the paint and they usually come right off! if not just reheat and try it again, once you get it off there will probably be some of the black foam still stuck on the panel, go to your local autoparts store (Advance or Autozone) and they should have a decal remover in a aerosal can spray some on the remaining adhesive and let it soak into the foam and just rub it off (may take awhile!) after it is all removed i use 3M Hand Glaze over the area if it is a older vehicle it will usually be discolored but on your new truck it won't be but if it was i would use a fine 3M buffing compound and machine buff out and then hand glaze it but you shouldnt have to. Hope this helps!
