engine light
Old Dec 30, 2003 | 06:50 PM
mccris's Avatar
mccris
Default engine light
I have a 2001 dodge ram with 24650 mi and the 5.9. The engine light will turn on when the gas tank is around half to three quarters full. If I fill it up and disconnect the battery the engine light will reset and will not turn on again untill the gas tank reachers the above level. It is most likley a sensor but my dodge dealer will not look at it unless I pay a $90 so called (refundable) fee for them to even look at it. They say if it is covered under warrenty then the $90 will be refunded. Has anyone else had this problem and if so was it covered under warrenty? thanks in advance
Old Dec 30, 2003 | 10:41 PM
the Mopar guy's Avatar
the Mopar guy
<IMG src=smileys/smiley4.gif border="0">YOU MIGHT CHECK YOUR GAS CAP. A LOT OF TIMES THE MOST </P>
COMMON CAUSE OF CHECK ENGINE LIGHTS IS AN EVAP LEAK. TRY </P>
TO TIGHTEN YOUR GAS CAP UNTIL IT CLICKS OR REPLACE IT.</P>
Old Dec 31, 2003 | 10:05 AM
71RoadRunner's Avatar
71RoadRunner
Yep, thats what my dads Rams' light came on for a couple years ago and it hasn't been on since.
Old Dec 31, 2003 | 02:42 PM
mccris's Avatar
mccris
thanks for the imput. I have checked the gas cap a number of times but still have the problem. Im not totally cheap but is the gas cap covered under warrenty. I mean come on, I live in a emmisions state and I have vehicles that are 20 years old and have no problems with vaper leaks through the gas cap? Just my opinion. Could it be in the vaper recovery system?
