Timing belt broke at 60mph Any Hope 4 me?
Old May 2, 2007 | 04:56 AM
Crazytrain101's Avatar
Crazytrain101
Default Timing belt broke at 60mph Any Hope 4 me?
[:@]The timing belt shredded at 60mph. At first I didn't know what was up cause the car just died. No loud noises or anything It just died and wouldn't start again. The shop told me the belt was toast and quoted me 2500.00 parts & labor. I can see the belt is broke and have heard horror stories about bent valves, holes in pistons ect. The motor Turns over freely with no unusual noises or binding. Should I tear the motor down to the short block to inspect the heads, pistons and valves or could I have gotten lucky and just need to replace the timing belt pullys and waterpump. Or would It be more cost effective to just replace the motor If I can find one reasonably priced. It is the 2.5 liter V6
Old May 2, 2007 | 05:43 AM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: Timing belt broke at 60mph Any Hope 4 me?
depends what kind of engine it is...might have gotten lucky
Old May 2, 2007 | 06:00 AM
03neonRT's Avatar
03neonRT
I would tear the motor down just to be sure...but then again, I only have four cylinders...so its easy for me to say that.
Old May 2, 2007 | 07:34 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I'm assuming that you have the 2.5L V6 Avenger (since you posted in there). The bad news is that you have a likely chance that you do have bent valves and pitted pistons because those 6g73 motors are "interference" motors. You were quoted $2500 because they are quoting you an engine rebuild. Sorry bro, but at 60mph, a timing belt breaking on you like that, spells bad news[>:]
Old May 2, 2007 | 03:30 PM
bad venge's Avatar
bad venge
Section Moderator
Personally I'd do a 3.0 swap ... I got one for $600 shipped and labor
