Headlights: High beams work great, low beams not so much
Old Sep 20, 2007 | 03:37 AM
Dually2's Avatar
Dually2
Default Headlights: High beams work great, low beams not so much
I have a 2001 Ram 3500 Sport that refuses to show its low beams. All the other lights work (including the high beams). The dashboard switch checks out fine and I have even replaced the multi-function switch in the steering column. No fuses are blown.
All suggestions are appreciated.
Thanks
Old Sep 24, 2007 | 09:39 PM
dishdude2k's Avatar
dishdude2k
Default RE: Headlights: High beams work great, low beams not so much
theres some relays in the power distribution box under the dash.. check em out..
Old Oct 11, 2007 | 09:40 PM
lara's Avatar
lara
It sounds like an electrical problem probably in the dashboard. Take it to a mechanic and let him know what the problem is, something electrical you should have a professional look at. My sister also had quite the same problem long time ago, she owned the Durango before and said she had to mess with the Dodge Headlights switch from time to time to get low beams to work then finally stopped working.[align=left] [/align]
Old Oct 16, 2007 | 12:36 AM
stonentwolf's Avatar
stonentwolf
Did you try replacing the bulbs?
