Safety Neutral Switch
Old Nov 8, 2007 | 09:31 PM
EF_Hatch's Avatar
EF_Hatch
Default Safety Neutral Switch
Ok, so I just did a search. Read over all post's concerning the safety neu. Here is whats going on. The car is a 98 Plym Neon, Auto trans. You turn the key and it try's to start, stops and clicks. Sometime's it just clicks. I have been told to check the safety neu switch. I am currently in the process. Just wanted to throw my problem out there for other idea's. The only code it is throwing is for clutch circuit/torque converter, but was told that wouldn't not let it start. Thanks guys.
Michael
Old Nov 11, 2007 | 01:20 PM
EF_Hatch's Avatar
EF_Hatch
Default RE: Safety Neutral Switch
bump
Old Jan 15, 2008 | 11:49 AM
clops79's Avatar
clops79
bad relay?
Old Jan 15, 2008 | 02:39 PM
ryanoyster1's Avatar
ryanoyster1
nuteral saftey should be easy to check all u have to do is unplug the sensor and ground it to the body. sounds to me like a bad starter relay or even a bad starter. have u tryed to start it in any other gears? like nuteral? or d or 321?
Old Jan 15, 2008 | 08:43 PM
bad venge's Avatar
bad venge
Section Moderator
First things first how is the battery and the cables....
Low voltage or corrosion can cause intermittant starting
Old Jan 17, 2008 | 12:27 PM
ryanoyster1
after thinking about it it could be the tc circuit. the tc could be in lockup causing the motor to "stall"
