dtc p0505 idle air control system
I have a 96 neon sohc that the check engine light came on. So i went to autozone and check it out and it had this code p0505. Then i went to the library and got the troubleshooting chart and went to work. i found nothing wrong with the system.i got another ecu but it still throuws the same code. Has anyone had this problem?
thanks.
thanks.
