Odd smell when defrost is turned on
Old Nov 27, 2007 | 08:08 AM
m00nwater's Avatar
m00nwater
Default Odd smell when defrost is turned on
I'm stumped by this issue and I hope you can help.
When I have the defrost turned on in my 1997 Dodge Grand Caravan, there is a very odd smell emitted. The only way I can describe this smell is a cross between something burning and something wet. It's very odd.
It only occurs when defrost is on. If regular heat is turned on it does not smell. Any ideas?
Thanks in advance.
Old Dec 1, 2007 | 11:15 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Default RE: Odd smell when defrost is turned on
The a/c compressor comes on with the defroster so the smell has something to do with the a/c....you probably have fungus build-up on your evaporator. That's the most common cause of the mildew smell...
Old Jan 3, 2008 | 09:51 AM
m00nwater's Avatar
m00nwater
Thanks for the input...I will check that as well since I have still had no luck figuring it out.
