95 dakota - surging, stalling, urgh
Old Nov 24, 2004 | 11:35 AM
rabbitcom1's Avatar
rabbitcom1
Default 95 dakota - surging, stalling, urgh
My V8 95 Dakota SLT- 187000 miles has been almost trouble free until
recently. Once my fuel hits just below 1/2 tank - it shakes, shutters on acceleration
and now stalls out. Once i fill the tank it runs like new until I hit 1/2 a tank.
My gauge is working since it takes about 10 gallans to fill up at that point.
I just can't fugure out why this happens at or just below 1/2 tank.
Any experience or tech advice?? Long live my dakota - the most reliable I have owned in a V8
Old Nov 24, 2004 | 12:54 PM
GMsucks's Avatar
GMsucks
Default RE: 95 dakota - surging, stalling, urgh
It is possible that the fuel pump is on it's way out.
Old Nov 27, 2004 | 08:53 PM
Big Green 4X4 98's Avatar
Big Green 4X4 98
My wife's car did that......Was a fuel pump prob!...Can't remember specifics though........Good luck
Old Nov 29, 2004 | 07:32 AM
casper's Avatar
casper
could be dirt, water or such in the fuel also.
Old Dec 11, 2004 | 09:44 AM
SnipeRT's Avatar
SnipeRT
It's hard to say what the problem is without actually working on the vehicle. But it sounds like your fuel pump pick-up tube has a leak in it somewhere. When the fuel level goes down to ~halfway, it will start sucking air into your fuel system. This could cause the exact problems you are describing.
To test, pick up a fuel pressure gauge and hook it up to your fuel rail next time your truck starts acting like that. Take note of the fuel pressure, and any trends (rising/lowering) as your truck stumbles/stalls. If your results indicate an air leak in the pickup tube, you are going to have to drain and drop the tank to repair/replace the fuel pump assembly.
