Engine eletrical arcing thru radio?
Old Dec 26, 2007 | 10:51 AM
jscott41's Avatar
jscott41
Default Engine eletrical arcing thru radio?
I have a 98 Dodge Intrepid. When I coast or deacclerate I can hear my engines' (coils, spark plug, wires) arcing through the radio speakers. How do I find out where the gap is, or problem above part. Thanks
Old Dec 26, 2007 | 11:21 AM
dishdude2k's Avatar
dishdude2k
Default RE: Engine eletrical arcing thru radio?
try re inforcing the ground on the stereo
Old Dec 28, 2007 | 08:14 AM
HankL's Avatar
HankL
a good place to start written in commom language:
http://www.popularmechanics.com/how_...66.html?page=2
there may also be Intrepid TSB's for radio frequency interference RFI
because similar TSB's exist for the Ram pickups
Old Dec 28, 2007 | 04:19 PM
oglejust's Avatar
oglejust
make sure the steel braided ground is connected to the radio
Old Dec 30, 2007 | 09:40 AM
bad venge's Avatar
bad venge
Section Moderator
I've taken an AM transistor radio and run it along the spark plug wires to find the loudest noise , I used the trick to find a bad spark plug wires that was arcing internally ...
Old Jan 15, 2008 | 10:29 AM
clops79's Avatar
clops79
sounds like time for a tune up or at least plug wire. also check all grounds(engine, battery, cab, chassis) all it takes is a little corrosion.
