water pump
Old Dec 29, 2007 | 04:25 PM
Doss henderson's Avatar
Doss henderson
Default water pump
hello! can anyone tell me how to get the cluch off the waterpump on my truck?thanks Doss
Old Dec 29, 2007 | 04:54 PM
noodle's Avatar
noodle
Default RE: water pump
What kind of truck is it?
Either way, im assuming you want to remove the fan and the fan clutch?
You need a wrench that will fit around the bolt behind the fan. Most parts stores carry them. Then you need a pry bar, cro bar, or anything to wedge into the fan itself or the bolts behind the fan so that you can unscrew the bolt and remove the fan itself, along with the clutch.
