Radiator Leaking
Old Jan 19, 2008 | 02:25 PM
rogrrr@hotmail.com's Avatar
rogrrr@hotmail.com
Default Radiator Leaking
I have a 97 Dodge 2500 that leaks coolant from between the core and end tank. I removed the radiator and pressure tested it to locate the exact spot where it was leaking. Then I squeezed the clamp ring with a pair of vice grips in that area. I stopped the air leak and reinsatlled the radiator.
It still leaks and I believe that the O-Ring in between the tank and core has taken a "set".
I need to locate a new clamp and the O-Ring rather than replacing the radiator, to the tune of $150.
Anyone know where I can buy these 2 parts ? I DAGS and could not find anything.
RoGrrr
