2005 Dodge Magnum Fuel gauge stock on empty, Bad cluster?
Old Feb 6, 2008 | 11:03 AM
rpm's Avatar
rpm
Default 2005 Dodge Magnum Fuel gauge stock on empty, Bad cluster?
I have a 2005 Dodge Magnum with a fuel gauge stuck on empty. When I connect the vehicle to a scan tool I am able to read the amount of fuel in the tank. The gauge never leaves Empty. Anyone seen this? A local dealer said the cluster is bad, but I talked to 3 different cluster shops and none of them have seen it.
Old Feb 7, 2008 | 07:22 PM
Parts/Service's Avatar
Parts/Service
Default RE: 2005 Dodge Magnum Fuel gauge stock on empty, Bad cluster?
Not sure this will help but there is a TSB relating to gauges being inaccurate...
Customer Satisfaction Notification D36
Instrument Cluster Gauge Accuracy
The instrument cluster on about 4,700 vehicles may display inaccurate
speedometer, tachometer, coolant temperature, and fuel gauge readings.
The instrument cluster gauges must be calibrated using the StarSCAN tool.
You might also want to try the cluster self diagnostic to see if it starts working...
The instrument cluster actuator test will put the instrument cluster into its self-diagnostic mode. In this mode the instrument cluster can perform a self-diagnostic test that will confirm that the instrument cluster circuitry, the gauges, and the indicators are capable of operating as designed. During the actuator test the instrument cluster circuitry will position each of the gauge needles at various calibration points and illuminate all of the segments in the Vacuum Fluorescent Display (VFD) units.
Successful completion of the actuator test will confirm that the instrument cluster is operational. However, there may still be a problem with the CAN data bus, the Powertrain Control Module (PCM), the Front Control Module (FCM), the Transmission Control Module (TCM), the Occupant Restraint Controller (ORC), the Controller Anti-lock Brake (CAB), or the hard wired inputs to one of these electronic control modules. Use a diagnostic scan tool to diagnose these components. Refer to the appropriate diagnostic information.
[ol][*]Begin the test with the ignition switch in the Off position. [*]Depress the odometer/trip odometer switch button. [*]While still holding the odometer/trip odometer switch button depressed, turn the ignition switch to the On position, but do not start the engine. [*]Release the odometer/trip odometer switch button. [*]The instrument cluster will simultaneously begin to illuminate all of the operational segments in both VFD units, and perform a bulb check of each operational LED indicator. The VFD segments and LED indicators remain illuminated as each gauge needle is swept to several calibration points and back. If a VFD segment or an LED indicator fails to illuminate, or if a gauge needle fails to sweep through the calibration points and back during this test, the instrument cluster must be replaced. [*]The actuator test is now completed. The instrument cluster will automatically exit the self-diagnostic mode and return to normal operation at the completion of the test. The actuator test will be aborted if the ignition switch is turned to the Off position, or if a vehicle speed message indicating that the vehicle is moving is received from the PCM over the CAN data bus during the test. [/ol]
Old Apr 22, 2008 | 09:32 AM
klinge's Avatar
klinge
My speedometer just stopped working out of nowhere. I have contacted 3 separate shops to trouble-shoot the problem and they all came back with the same answer. I need to replace the whole instrument cluster for around $1200.00! Apparently the clusters are vin coded so I cannot simply replace it myself without messing up the computer system. Also, Chrysler's customer service refuses to back -up their product and will not replace the component. Why can’ Dodge/Chrysler make a product that will last longer than 2-3 years? Is anyone aware of a way around this mess?
