Is my motor shot??
Old Feb 22, 2008 | 12:52 AM
rare aries's Avatar
rare aries
Keeper of the Ks
Default Is my motor shot??
My wife let the engine in our 87 K over heat to the point it stalled and wouldnt start. When you turn the key it turns over but sounds like a a lawn tractor turning over. A mechanic looked at it and it has low compression in 3 cyl, there is no oil in the coolant or vice versa, he said he could fix it cheap but its going to use oil ( before this happened it used a half a quart between changes.) because the temper in the rings might be gone this is causing the low compression. Before I start thinking about a new engine or rebuild, what else should be looked into Im having another mechanic look at, I did feel confident in the one my car was towed to.
The engine was maintained on a regular basis from new I know this from looking at its service records from day one that came with it when I bought it. I hope to get it up and running for the spring.
Old Feb 22, 2008 | 03:41 PM
moparborn's Avatar
moparborn
Default RE: Is my motor shot??
You might have head damage,that is often the first thing to happen.
You can try doing a leakdown test and see where you are loosing the air,or just pull the head and check everything because it has to come apart anyway.
Old Feb 22, 2008 | 05:20 PM
rare aries's Avatar
rare aries
Keeper of the Ks
Thats what I was thinking, thankfully if the head is toast I still get new one from NAPA for $450 + core.
Old Feb 22, 2008 | 06:01 PM
moparborn's Avatar
moparborn
From what I hear,you might also consider a water pump and timing belt while you are in there.
Old Feb 22, 2008 | 07:08 PM
rare aries's Avatar
rare aries
Keeper of the Ks
Thanks for the tip.
