2000 caravan trans slipping DTC 3300?
Old Mar 16, 2008 | 05:27 PM
nissan tech's Avatar
nissan tech
Default 2000 caravan trans slipping DTC 3300?
I have a 2000 caravan 3.0l with a 4 speed auto box I have been asked to check out. The problem is it starts out strong in 1st then it is line it goes to neutral on 1-2 shift. engine revs. doesn't matter if you manually down shift. I let off coast to the side and wait a few seconds and you can feel when the trans engages again. Goes if you don't use too much throttle. but I only drove it to my house .5 mile, Cold stall tests fine. Trans fluid is clean and fresh. Also has SES light on and has code P3300. I can not find any thing on this code in Mitchell manuels. I'd be very happy for any help. Thanks
If any one needs any Nissan help I 'd be more than willing to help.
