jb weld
Old Mar 30, 2008 | 09:55 PM
LayItLowS10's Avatar
LayItLowS10
Default jb weld
three of the four bolts holding the throttle body to the intake manifold snapped inside the manifold. for the past weekend ive been using the remaining bolt and some high heat silicone. its starting to wear. will jb weld work to seal the tb to the manifold (also still using the remaining good bolt) until im back home in 2 weeks or so.
im not looking for ppl to tell me to just fix, i would if i could right now ... just curious as to whether or not the jb will hold me over for now. thakns
Old Mar 30, 2008 | 10:16 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: jb weld
it's far easier to get an easy out and drill the bolts and get them out then trying to use JB weld to "fix" it ... that stuff is terrible to get out when you try to fix it right ... IMO drill them and easyout , or get a new manifold at the junkyard I paid $20 for one with TB
Old Mar 31, 2008 | 05:53 AM
LayItLowS10
Default RE: jb weld
already tried to easy out em, didnt work. just need to get the d home so i can swap in a new mani/tb .... just need something thatll hold for a few more hundred miles
Old Mar 31, 2008 | 10:36 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: jb weld
really weld it ...
Old Mar 31, 2008 | 07:24 PM
moe7404's Avatar
moe7404
Default RE: jb weld
moe in wichita ks
a friend told me a store about j b weld. he was helping out on a top
alcohol digger. on sat trying to
qualify the engine block split wide open. they sent someone to town a got 30 packages of j b weld. they stayed up all night j b welding the block back together. on sun they went 3 rounds, before a narrow loss. if you dont beleave me i can give you my friends name.
Old Mar 31, 2008 | 08:51 PM
moparborn's Avatar
moparborn
Default RE: jb weld
If the throttle body is not moving and is still tight in place,just put a heavy bead of silicon around the joint,remember no fuel goes through the throttle body,just air.
Old Mar 31, 2008 | 08:58 PM
LayItLowS10
Default RE: jb weld
well the jb weld has held thus far. about halfway home. should be home tomorrow afternoon. if i had the tools i would have fixed it properly. i was just looking for a quick fix so i could get home toactually fix it. i tried the silicone the first time. after about a hundred miles of 75 mph driving it eventually wore off, and i was using high heat silicone.
