Cooling fan
Old Apr 17, 2008 | 07:50 PM
fireman2118's Avatar
fireman2118
Default Cooling fan
Hey all,
Well I'm thinking that my cooling fan motor is going out. It works sometimes.....mostly not. I've got the GSM fan mod installed. It was working fine then all of a sudden off and on. I've checked the wiring - ok
I've replaced the switch and swapped relays.....sigh. Anyway, I called GSM and they said it may be the fan motor. Anyone have any history with a fan/fan motor install? Thanks in advance
Bill[/align]
Old Apr 18, 2008 | 08:23 PM
moe7404's Avatar
moe7404
Default RE: Cooling fan
moe in wichita ks
check the ign switch. somtimes the contacts for the heater burn out. thats why you should turn the heater system off with the heater switch, before you turn off the ign swicth. same with a microwave, turn it off with the button not the door.
