LED Replacement Bulbs
Old Jan 11, 2005 | 01:47 AM
94ram4x4 5.9's Avatar
94ram4x4 5.9
Default LED Replacement Bulbs
I replaced my tailights today with 3157 LEDs and my brake and turn signal fuses were blown when I got home....I did the swap because the running light filament on the driver's side was out, and now I am in the same situation, but the bake lights and turn signals don't work....has anybody else made this swap and had similar problems? I plan on checking the voltage and looking for short througout the wiring tommorow( It's too cold outside right now!)..any help would be great. Thanx
Old Jan 11, 2005 | 01:55 AM
casper's Avatar
casper
Default RE: LED Replacement Bulbs
I would say you have a short, LED bulbs use far less power than regular bulbs. Look for broken wires.
Old Jan 11, 2005 | 09:58 AM
thump186's Avatar
thump186
we sell these at work and have people return them with the same complaints. the same thing happened to me and i know i dont have any shorts. are they apc by any chance?
Old Jan 13, 2005 | 12:39 AM
94ram4x4 5.9
Alright, after hours of tracking wires and studying wiring diagrams, I found the problem! Bulbs! The bulbs are in fact made by APC and they are supposed to replace a 3157 Bulb. I replaced my parking lights with blue 3157's (also from APC) and they work fine! The rears however kept blowing the brake and turn signal fuses(15a). I used the clear 3057s I had in the parking lamps and it worked fine! I don't know if there is some big difference in 3057 and 3157 bulbs, but either works fine in the parking lights! Maybe it is just the LEDs. I plan on emailing APC and asking them what the deal is....no big deal but I was worried I had a lot bigger problem on my hands! thanx for the input
Old Jan 14, 2005 | 01:30 AM
casper's Avatar
casper
wow, an LED uses less power than a regular bulb. Must be something wrong with the bulbs. Thanks I was thinking about gettin the LED bulbs from APC, i'll find another company now.
Old Jan 14, 2005 | 02:55 AM
injmopar's Avatar
injmopar
Check the led bulb with an ohm meter. It should be 180 ohms or more. Reversed polarity should show no conductivity, or it would be a dead short.
Old Feb 12, 2005 | 04:01 PM
Interpid199433's Avatar
Interpid199433
The first thing is LED lights will make your turn signal flash fast becuse it thinks there is a burnt out light bulb and the second thing is APC led suck I would retrun them and get Jam Stait LED auto zone has them they have a 10 year replacement I have them and they have not given me any problems I would go to there web site at http://www.jamstrait.com/products.html. They have Load Equalizers to make your turn signal flash like normal hope this helps.
