coolant for 5.7L ram 1500
Old May 16, 2008 | 07:39 AM
RamRoddin5.7's Avatar
RamRoddin5.7
Default coolant for 5.7L ram 1500
What brands/models of coolant work well with the 5.7L ram v8's? Mine is a 2005 if it matters.
Thanks in advance guys!
Also, this is my first good size truck. Is it normal to blow through 1/4 to 1/5 a tank of coolant within a month or so with a 5.7L v8 or should i be worried?
take care
-RamRoddin'
Old May 21, 2008 | 08:37 PM
Truck Dude's Avatar
Truck Dude
Default RE: coolant for 5.7L ram 1500
you shouldnt be losing any coolant, its a closed system. fire it up and look under the hood and see if you see any of the hoses leaking. do you see any fluid on the ground when its parked in one spot for a while? do you smell something sweet in the air when its running or when you walk by it after its up to temp?
hope it helps.
