93 Jeep engine cutting out at steady RPMs
Old Jan 16, 2005 | 10:50 PM
Leonard's Avatar
Leonard
Default 93 Jeep engine cutting out at steady RPMs
My buddy has a 4 cylinder Jeep that has started cutting out when he is running along maintaining a constant RPM.
It usually runs fine and he has replaced the wires, plugs, cap, and rotor but not the coil.
I thought it may have been a bad O2 sensor behind the Cat but he does not have one behind the Cat.
Any ideas what may be causing this?
My next guess was maybe a fuel regulator.
Old Jan 16, 2005 | 11:16 PM
casper's Avatar
casper
Default RE: 93 Jeep engine cutting out at steady RPMs
I had an 86 cherokee that would do the same thing, it died one day and would not start. I left it there over night and in the morning I came back and it started right up. Never had any problems with it again, and never figured out what it was.
Old Jan 16, 2005 | 11:40 PM
moparmania's Avatar
moparmania
is the engine light on at all? try a good injecter cleaner like lucas, i hads the same problem with my 95 yj but i changed the o2 sensor, fuel filter and used the injector cleaner , and it cleared up , also the cats on those like to get clogged up after a bit too.
Old Jan 17, 2005 | 12:12 AM
Leonard's Avatar
Leonard
No his Check Engine Light is not on.
He did mention it backfireing on occasion through the intake?
So would that sound like a clogged cat?
This may be his excuse to cut the cat out and start trailering it to the lease.
Old Jan 21, 2005 | 09:49 AM
Leonard's Avatar
Leonard
Default Thanks, he replaced the O2S and it is running fine
He replaced the O2S and it is running fine
Thanks for the help; he emailed me the other day saying thank you.
Said that it was running smoother and had ran fine without a warm up;
previously that was one of the times it would happen.
