How to… fuel cell in bed of truck?
Old May 31, 2008 | 06:33 AM
dodgebuzz's Avatar
dodgebuzz
Default How to… fuel cell in bed of truck?
Was thinking of putting a 22 gal fuel cell in bed but keep the stock tank? Is there a way to make it so that the fuel run to stock tank?this is what I have, Also hade a stele box made for it
Old May 31, 2008 | 09:25 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: How to… fuel cell in bed of truck?
Not familiar with the newer dakota's is the fuel pump IN the stock tank ???
Old Jun 1, 2008 | 12:40 AM
dodgebuzz's Avatar
dodgebuzz
it is all stock I think it is in the tank.
Old Jun 1, 2008 | 09:50 PM
bad venge's Avatar
bad venge
Section Moderator
probably the best way is to get a second fuel pump and mount it in the fuel cell then "t" that into the stock fuel line then have a switch to go from the stock tank to the fuel cell ....
trying to run the cell into the stock tank gravity fed ect will cause huge headaches as the cell is larger then the stock tank
Old Jun 4, 2008 | 08:27 AM
Truck Dude's Avatar
Truck Dude
taking a guess but...
cant you just put a hose going from the new tank to thestock tank with a valve on it so when the stock tank is getting low, you can just transfer the fuel by opening the valve?
I dont see a point in putting another fuel pump with a switch and all, its too complicated and thats just one more thing that could fail if you ask me..
