Dodge caravan 93 3.3L no spark
Old Jun 4, 2008 | 09:57 AM
michaeljancha's Avatar
michaeljancha
Default Dodge caravan 93 3.3L no spark
Problem #1 no spark
The engine ran before I changed the transmission.Problem # 2 I could only line up 3 out of the for torch converter bolts
Old Jun 5, 2008 | 01:04 AM
tom01973's Avatar
tom01973
Default RE: Dodge caravan 93 3.3L no spark
remove the converter bolts and turn it until all the bolts line up then reinstall all the bolts and torque them down then try to start it.i bet it starts right up.if not then check the crank sensor
Old Jun 5, 2008 | 09:49 PM
michaeljancha
I removed the converter bolts and turned it until all the bolts line up then reinstalled all the bolts and torqued them down then I tryed to start it. No sparkI aujustedthe crank sensor and now it runs.
Now I have a knock cumming frum the bottem of the engin or the converter.
do you know howmuch fluid to put into the transmishion?
Old Jun 6, 2008 | 01:27 AM
tom01973's Avatar
tom01973
if it didn't knock before you changed the trans.then something is loose somewhere.check the bolts for the converter again and make sure they are bottomed out on the flex plate.also check the bellhousing boltsand the mounts as well.last on i did needed about 8qts but it had a new converter and fresh rebuild.is this a used trans or a rebuilt unit? a used trans will probably take 5-6qts.
