Need help with A/C compressor!!!!!!!
Old Jun 8, 2008 | 11:08 PM
terrymaiorana's Avatar
terrymaiorana
Default Need help with A/C compressor!!!!!!!
My A/C compressor won't turn on. All fuses are good. Tried switching around all relays hoping to move problem. No luck. I don't get any voltage at compressor in either auto or manual modes. Not sure if I have a bad wire or bad connection. I need either tech. help or wire diagram. Also need to know which relay does what. Owners manual doesn't list info on any relays. I have 170000 kms. on car so no warr. Thank-you for any help.
Old Jun 12, 2008 | 01:19 AM
tom01973's Avatar
tom01973
Default RE: Need help with A/C compressor!!!!!!!
you need to check if the system is fully charged.if it ins't charged then the low pressure switch will not close and no voltage will be sent to the compressor.
