Stripped Lug nut - how to remove
Old Jul 13, 2008 | 06:00 PM
cakley's Avatar
cakley
Junior Member
Default Stripped Lug nut - how to remove
My Dodge Ram had some cheap chrome lug nuts on it. One of them was rounded off and I couldn't get a socket on it.
I attempted to use a high speed cut off wheel so now all I have is the very bottom portion holding on the rim. [:@]
How do I fix this[:-]?
Old Jul 13, 2008 | 06:06 PM
cakley's Avatar
cakley
Junior Member
Default RE: Stripped Lug nut - how to remove
Only two options I can think of are: heat up whats left of the cheap metal lig nuts and attempts to beat the rim off. Or use a small drill bit and eat away at the little bit of metal thats left.
Last option would be to tear up the stock steel rim.
Old Jul 13, 2008 | 07:37 PM
bad venge's Avatar
bad venge
Section Moderator
Next time try the damaged bolt remover from Sears before you whittle it away ... Unless you can get it to reach the leftover
Old Jul 13, 2008 | 07:42 PM
moe7404's Avatar
moe7404
moe in wichita ks
take the rotor/drum off. find someone with a realy powerful hyd press. try a machine shop. and just punch out the stud striping the threads on the nut, but not hurting the wheel.
