hi, need some help with a coolant leak thought it might be the H2o pump but not sure the pump is the only thing clean and dry i have pink crust all over the bottom of the motor its starting to sling over the rest of the engine compartment mainly on my air cleaner and the upper rad hose. is there any way to tell if the water pump is going out? the temp stays around 200 thanks for any help
