1995 intrepid trans problem
Old Feb 5, 2005 | 01:45 AM
djt95int's Avatar
djt95int
Default 1995 intrepid trans problem
I recently "inhereted" a 1995 intrepid with 92000 miles on it but a couple of days ago the transmission quit working on me. After i pulled off it started to work but only with 2nd, and reverse. ive been told this is a limp mode it has. anyone know why it would do this or how to fix it? any help is appreciated
Old Feb 10, 2005 | 11:34 PM
djt95int's Avatar
djt95int
Default RE: 1995 intrepid trans problem
i need some help with this car anyone have this prob before??????????????
Old Feb 11, 2005 | 02:31 AM
justaocboy's Avatar
justaocboy
yes,not a problem its the trans fail safe method,its stoping you from doing damage to the trans,get it ck out its most likely something
small,input or output sensor.
Old Feb 18, 2005 | 01:00 AM
djt95int's Avatar
djt95int
thanks but it turns out it was collapsed oil lines and i had to get a new tranny
Old Mar 16, 2005 | 01:38 PM
tgaf1949's Avatar
tgaf1949
I am having this same problem on my Dodge Dynasty 1993. 18 degrees here this am, that is frozen transmission lever. I am new to forum and see that there are 5 posts listed, but I can only see three. Also can't start car. Dead silence from engine, however tape tack and heater come on just fine.
Old Mar 17, 2005 | 01:30 AM
djt95int's Avatar
djt95int
sounds like a sensor such as a transmission sensor so it wont start the car while its in gear, or some other sensor on the engine. but i believe that is the most likely
