2001 Neon Stalling at idle
Old Mar 14, 2005 | 12:07 AM
sxvipers's Avatar
sxvipers
Default 2001 Neon Stalling at idle
The car will stall at random, the idle is not consistaint the it stalls. I have had the pcm updated but i am not sure if it is the latest update for the car. Is there a way to tell?
Old Mar 14, 2005 | 12:11 AM
casper's Avatar
casper
Default RE: 2001 Neon Stalling at idle
Try a general tune up. Plugs, wires, air filter, injector cleaner.
Old Mar 14, 2005 | 12:19 AM
sxvipers's Avatar
sxvipers
I have already done that.
Old Mar 21, 2005 | 02:36 AM
mopar714's Avatar
mopar714
hello try cleaning the throttle body out and the iac motor in the throttle body if that dosent help replace the iac motor good luck
Old Mar 21, 2005 | 02:43 AM
casper's Avatar
casper
Check your fuel pressure at the fuel rail. If its low, either a fuel pump or filter. Could be the iac, but check to see if you have full presure 1st.
