PCM fault please I need help !!!
Old Mar 26, 2005 | 01:28 PM
raygauthier245's Avatar
raygauthier245
Default PCM fault please I need help !!!
hi there !!
this is my problem is a fault code .
I have a 97 Dodge Ram laramie 5.9L 360 with a code that reads
Code 43 Ignition coil circuit #
Open or short in number # coil circuit. Indicates that the ignition coil's peak primary circuit current is not achieved with the maximum dwell time.
but if you go under the truck it makes a noise like a rattle like small rocks in a coffee can coming from the catalytic converter and it is just beside the transmion hard to tell if it from the transmion or catalytic converter.
When i am driving a have a lack of power and you can here the rattle.
So my Question is can a catalytic converter bring up this codes or is my truck in bad need of help
Did this happen to anyone
[sm=gears.gif]
