need help with 1993 dodge shadow 2.2L
Old May 16, 2005 | 11:10 AM
trevor's Avatar
trevor
Default need help with 1993 dodge shadow 2.2L
this is my first post. here are the symptoms in my 1993 dodge shadow
runs well on start up, does not start on first turn of key, makes henious sound sometimes sneazes out of throtle body(timing?)
pops once in a while out the tail pipe. not a loud pop but enough to hear and feel (again timing?)
when it gets warm it sounds like a cylander is not firing properly. it starts as one then starts to bog down the car. it wants to stall but will run if i give it gas. but after a while ther is little responce from the car. the rpms slowly bounce down to 0 if i am stopped at a sign or light. its fine sometimes if i put the tranny in N.
what i have already done:
new air filter, replaced lots of vaccume hoses and t fitting on the manifold and egr valve, replaced pcv valve and elbow.
please help
Old May 18, 2005 | 02:39 PM
trevor's Avatar
trevor
Default RE: need help with 1993 dodge shadow 2.2L
i thought this was a forum? dosent anyone have any ideas?
