oil pane torgue settings
Old May 20, 2005 | 07:47 PM
hoppy's Avatar
hoppy
Default oil pane torgue settings
93 dodg intrepid es torgue settings for the oil pan?
Old May 20, 2005 | 07:49 PM
Drew's Avatar
Drew
Default RE: oil pane torgue settings
I would say german torque standards. . good-n-tite
but not tight enough to crack the gasket
Old Jun 2, 2005 | 11:39 PM
Parts/Service's Avatar
Parts/Service
TORQUE CHART - 3.5L
DESCRIPTION TORQUE
A/C Compressor to Engine Block
Bolts 41 N·m (30 ft. lbs.)
A/C Compressor to Bracket
Bolts 23 N·m (200 in. lbs.)
Generator Bracket
Generator Mounting
Bolt (M8 x 1.25 Bolt)31 N·m (270 in. lbs.)
Camshaft Sprocket Bolt
Right Side 102 N·m (75 ft. lbs.) plus 1/4 turn
Left Side 115 N·m (85 ft. lbs.) Plus 1/4 turn
Camshaft Thrust Plate (Camshaft Cover)
Bolts 28 N·m (250 in. lbs.)
Timing Belt Cover Bolts
M6 12 N·m (105 in. lbs.)
M8 28 N·m (250 in. lbs.)
M10 54 N·m (40 ft. lbs.)
Connecting Rod Cap
Nuts 54 N·m (40 ft. lbs.) Plus 1/4 turn
Crankshaft Main Bearing
M10 Tie Bolts 54 N·m (40 ft. lbs.)
M11 Cap Bolts 41 N·m (30 ft. lbs.) Plus 1/4 turn
Crankshaft Damper
Bolt 115 N·m (85 ft. lbs.)
Cylinder Head Bolts
Step 1 61 N·m (45 ft. lbs.)
Step 2 88 N·m (65 ft. lbs.)
Step 3 88 N·m (65 ft. lbs.)
Step 4 Plus 1/4 turn Do not use torque wrench
Cylinder Head Cover
Bolts 12 N·m (105 in. lbs.)
Exhaust Manifold to Cylinder Head
Bolts 23 N·m 200 in. lbs.)
Exhaust Manifold Heat Shield
Bolts 12 N·m 105 in. lbs.
Exhaust Pipe Flange
Nuts 34 N·m (25 ft. lbs.)
Engine Mount Bracket to Block
Bolts 88 N·m (65 ft. lbs.)
Engine Mount Insulator
Nuts 61 N·m (45 ft. lbs.)
Intake Manifold
Oil Pan
Oil Pan Drain
Plug 35 N·m (25 ft. lbs.)
Oil Filter
Hope this helps
Old Feb 3, 2007 | 06:00 AM
Bumble45's Avatar
Bumble45
wow very detailed..
I am looking for some similar torque specs...
o2 sensor? exhaust manifold bolts? motor mounts?
installing headers and cat back tomorrow
on a magnum
TIA
