Engine misfire
Old May 29, 2005 | 12:25 AM
Valk's Avatar
Valk
Default Engine misfire
Can anyone give me some suggestionson my 2002 ram 1500 (360) 2 wheel drive quad cab. When I first fire the engine it shakes and msifaire like crazy. I have done all the standard things you may first try like plugs/ wires / cap and filters. Could there be a bad sensor ? As the engine warms it starts to smooth out, but will still stumble at a steady speed but not as bad as when first started. I am really frustrated with this truck, (44,000 miles) and it is super clean. The thing I hate the most is the wonderful 10.4 miles per gallon it gets. This is completely empty and not pulling anything. [>:]
Thanks
Mark
p.s. no engine codes or check engine light as of this moment
Old May 29, 2005 | 03:05 AM
moparturd's Avatar
moparturd
Default RE: Engine misfire
Maybe a coil pack is going bad, or a fuel injector is sticking?
Old May 29, 2005 | 12:16 PM
kota98's Avatar
kota98
Ive heard a bolt(s) on intake man loosening up can make an engine misfire
You can try retorqing the intake
RIck
Old May 29, 2005 | 01:37 PM
moparturd's Avatar
moparturd
I thought they fixed the plenum gasket problem on the 360s.
Old May 29, 2005 | 07:35 PM
roachnigga's Avatar
roachnigga
Check ya pcv it maybe clogged.... what gas are you using? i agree with ya coil pack, you may not getting the current needed thru ya wires?
Try also reseting ya ECU
