1995 Intrepid codes 23 and 64
Old Jun 8, 2005 | 11:05 PM
jkmdieff's Avatar
jkmdieff
Default 1995 Intrepid codes 23 and 64
On the advice of a shop, I replaced the Power Control Module. After installing, the check engine light came on. Was not on before, was having intermittant power issues. Code I get are 12-64-23-64-55. I know 12-battery disconnect (which I did to try and reset check engine light) and 55-end. Anyone know what 23 and 64 are? 1995 Intrepid, 3.3 liter engine. Thanks.
Old Jun 9, 2005 | 02:44 PM
jkmdieff's Avatar
jkmdieff
Default RE: 1995 Intrepid codes 23 and 64
Ok, according to the list DodgeGirl put up there, code 23 is intake air tem sensor out of range and 64 is Catalytic Converter Efficiency failure. Neither sounds like something I am going to want to pay to fix right now since I have just sunk another $1000 into this machine in the past month. New ???--Does this check engine light ever turn off by itself? If so, when? Is there someway to turn it off?
jkmdieff
