Black Smoke...
Old Jul 6, 2005 | 04:23 PM
Piezo's Avatar
Piezo
Default Black Smoke...
I have a 1989 3.0L Caravan, after I changed the distributor cap, rotor and spark plugs, plug wires and air filter the van as been pumping black smoke out. When I remove the intake from the air filter box there's a small puddle of gas...ie, its burning rich and hence the black smoke. Does anyone have any ideas on what is causing it?? The van was badly maintained before, and the plugs I took out was very worn. Could it be the O2 sensor????
Old Jul 6, 2005 | 06:54 PM
roachnigga's Avatar
roachnigga
Default RE: Black Smoke...
Yes, Check ya O2.
Old Jul 8, 2005 | 02:15 AM
JCswm's Avatar
JCswm
I'd get codes & suspect your engine coolant temp sensor reads like -34 giving the pcm a FULL RICH condition
Old Jul 8, 2005 | 03:25 AM
Piezo's Avatar
Piezo
The codes says 12 and 55. Which means nothing according the OBD guide. I changed the O2 sensor but it still has difficulty starting when its fully at temperature and when it does start i get a puff of black smoke. Could it still be the temp sensor??
When the car gets started, the idle is rough and the rpm needle hops around.
Old Jul 8, 2005 | 03:28 AM
Piezo's Avatar
Piezo
I'm also suspecting its the coils..any thoughts?
Old Jul 18, 2005 | 07:05 AM
faustburger's Avatar
faustburger
Maybe wrong sequency on plug wires?I meand couple of cylinders not working on right time and leading
unburned gas to exhaust....
Old Jul 18, 2005 | 03:45 PM
roachnigga's Avatar
roachnigga
When was ya last tune up? You may have bad plugs & wires
Old Jul 20, 2005 | 03:43 AM
s22479a's Avatar
s22479a
check your firing order first. its easy to mess it up on a 3.0 a 3.0 will run pretty decent even with 3 wires pulled off. flip the cap over and look at the way it is made. the inside contacts dont correspond with the towers above. if that is fine then put a scanner on it and look at the map reading. an oil contaminated wheatstone bridge can cause chaos. look for oil in the vac line to the map sensor.
Mike
Old Jul 20, 2005 | 05:12 AM
Brock0295's Avatar
Brock0295
piston rings
Old Jul 20, 2005 | 06:56 AM
roachnigga's Avatar
roachnigga
lets hope thats not it.. but its a poss
