info on tires and fitment
Old Aug 8, 2005 | 11:45 AM
thump186's Avatar
thump186
Default info on tires and fitment
WHEEL FITMENT
Correct fitment of tires and wheels is of essential importance. Improper combination of tires and wheels lead to incorrect speedometer display, increased fuel consumption and decreased stability of the vehicle.
WHEEL SIZE
Alloy wheel parameters Wheel sizes are expressed as WW x DD sizes. For example 6 x 14. A 6 x 14 wheel is has a rim width of 6 inches, and a rim diameter of 14 inches. The width is usually below the width of the tire for a good match. So a 185mm tire would usually be matched to a wheel which is 6 inches wide. (185mm is more like 7 inches, but that's across the entire tire width, not the bead area where the tire fits the rim.)
ROLLING RADIUS
The important thing that you need to keep in consideration is rolling radius. This is the distance in mm from the center of the wheel to the edge of the tread when it's unladen. If this changes because you've mismatched your new wheels and tires, then your speedometer will lose accuracy and the fuel consumption might go up. The latter reason is because the manufacturer built the engine/gearbox combo for a specific rolling radius.
Why would I want to put larger wheels?
Styling and performance are the only two reasons. Most cars come with narrow little tires and 13 inch rims. More recently the manufacturers have started putting decent combinations on factory cars so that's not so much of a problem any more. The first reason is performance and more specifically stability in corners at high speed. If you have larger rims, you get smaller sidewalls on the tires. And if you have smaller sidewalls, the tire deforms less under the immense sideways forces involved in cornering, thus making the car more stable.
The Plus One concept
The plus one concept easily describes the proper sizing up of a wheel and tire combination. Basically, each time you add 1 inch to the wheel diameter, add 20mm to the tire width and subtract 10% from the aspect ratio. This compensates for the increases in rim width that generally accompany increases in diameter too. By using a larger diameter wheel with a lower profile tire it's possible to properly maintain the overall rolling radius, keeping odometer and speedometer changes negligible. By using a tire with a shorter sidewall, you gain quickness in steering response and better lateral stability. The visual appeal is obvious
Old Jun 3, 2006 | 10:25 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: info on tires and fitment
In agreeance/agreement to Thumps statement above in the first paragraph, I wanted to post some aids/tools in calculating correct tire/rim combinations. You do have to know what the stock values are but you most likely already do or you will
This from 1010 tires.com to help in guiding wheel buyers...
Wheel offset calculator
And here's a tire size calculator from the same site...It helps in determining whether your speedo will be off or not and if it is, it'll help determine how much faster/slower your wheel will turn in referrence to the stock size wheels.
Tire Size Calculator
This is just a guide and not the bible to buying wheels.
Hope this helps...
Old Jun 14, 2006 | 06:16 AM
kent_08's Avatar
kent_08
Yes I agree. I had a n experience before when I was really impressed by a cool pair of wheels and tires. the design is really awesome so I was enticed to buy. Yet, the pair would not fit my car. I was really dissapointed and I ended up spending my money in vain. Anyway the point is, check out your car's spec first before buying any part for replacement or add-on.
