5.9L 360 CID info
Old Aug 13, 2005 | 06:21 PM
thump186's Avatar
thump186
Default 5.9L 360 CID info
The 5.9L 360 CID eight cylinder engine is a V-type, lightweight, single cam, overhead valve engine with hydraulic roller tappets. This engine is designed to run on unleaded fuel with a minimum octane rating of 87. Engine lubrication system consists of a rotor type oil pump and a full flow oil filter.The cylinders are numbered from fron to rear, with cylinders 1, 3, 5, 7 on the left side and 2, 4, 6, 8 on the right side.
Valves are arranged in-line and and inclined 18 degrees. Rocker pivot supports and valve guides are cast integral with the heads.
Pistons are elliptically turned so that the diameter of the pin boss is less than the diameter accross the thrust face. This allows for expansion under normal operating conditions. When the piston warms to operating temperature, expansion forces the the pin bosses away from each other, causing the piston to assume a more nearly round shape. All pistons are machined to the same weight regardless of size, to maintain piston balance. The piston pin is pressed into the connecting rod.
Engine Type
360 cid 90' V-8 OHV
[1997 Curves]
1994 Engine Serial Number
X M 5.2L T YYYY XXXXXXXX
X=last digit of model year
M= Plant - Mound road
o S- Saltillo
o T - Trenton
o K - Toluca
5.9L=engine displacement
T=usage (truck)
YYYY=Month/Day
XXXXXXXX=8 digit serial no
2000-2001 Engine S/N
X M 318 YYYY XXXX
o S- Saltillo
o T - Trenton
o K - Toluca
360=engine displacement (CID)
YYYY= Month/Day
XXXX=Engine Serial Code
Bore & Stroke
4.00 x 3.58 in. (101.6 x 90.9 mm.)
Displacement
360 cu.in. (5.9 L)
Compression Ratio
9.1 :1
Horsepower
245 hp @4000 rpm
Torque
330 ft. lbs. (448 N.m) @ 3250 rpm
Firing Order
1-8-4-3-6-5-7-2
Lubrication
Pressure Feed - Full Flow Filtration
Engine Oil Capacity
5.0 Qts. (4.7 L) with Filter
Cooling System
Liquid Cooled - Forced Circulation
Cooling Capacity
15.5 Qts. (14.7 L)
Cylinder Block
Cast Iron
Crankshaft
Nodular Cast Iron
Cylinder Head
Cast Iron
Combustion Cambers
Wedge - High Swirl Valve Shrouding
Camshaft
Nodular Cast Iron
Throttle Body Bore 50 mm
Pistons
Cast Aluminum Alloy
Spark Plugs: 14mm thread, 19mm reach, 16mm hex wrench, resistor
Year Manufacturer Part No. Stock Number Gap Notes
1994-1995 HD NGK WR5 2438 .035
1994-1995 HD NGK WR5VX 4385 .035 Platinum
1996-1997 NGK FR4 5155 .035
1998-1999 LD, HD NGK FR5-1 7252 .040
Camshaft - Nodular Cast Iron
Bearing Number 1 2 3 4 5
Bearing Diameter mm 50.800 - 50.825 50.394 - 50.419 50.013 - 50.038 49.606 - 49.623 39.688 - 39.713
in 2.000-2.001 1.984-1.985 1.969-1.970 1.953-1.954 1.5625-1.5635
Journal Diameter mm 50.749-50.775 50.343-50.368 49.962-49.987 49.555-49.581 39.637-39.662
in 1.998-1.999 1.982-1.983 1.967-1.968 1.951-1.952 1.5605-1.5615
Diametrical Clearance: 0.0254-0.0762 mm, 0.001-0.003 in
Max Allowable: 0.127 mm, 0.005 in
End Play: 0.051-0.254 mm, 0.002-0.010 in
Connecting Rods - Forged Steel
Bearing Clearance 0.0127-0.0559 mm, 0.0005-0.0022 in
Piston Pin Bore Diameter 24.966-24.978mm, 0.9829-0.9834 in
Side Clearance (two rods) 0.152-0.356mm, 0.006-0.014 in
Total Weight (less bearing) 758 grams, 25.74 oz
Crankshaft - Nodular Cast Iron
Connecting Rod
Journal Diameter . . . . . . . . . . . . . 53.950-53.975 mm, 2.124-2.125 in
Out of Round (max) . . . . . . . . . . 0.0254 mm, 0.001 in
Taper (Max) . . . . . .. . . . . . . . . . 0.0254 mm, 0.001 in
No 1: . . . . . . . . . . . . . . . . . . . . . . . . . 0.0127-0.0381 mm, 0.0005-0.0015 in
Max Allowable (No 1) . . . . . . . . . . . 0.03815 mm, 0.0015 in
No 2, 3, 4, and 5 . . . . . . . . . . . . . . . . 0.0127-0.0508 mm, 0.0005-0.0020 in
Max Allowable (Nos. 2, 3, 4, & 5) . . 0.0635 mm, 0.0025 in
End Play . . . . . . . . . . . . . . . . . . . . . . . 0.051-0.178 mm, 0.002-0.007 in
Max Allowable . . . . . . . . . . . . . . . . 0.254 mm, 0.010 in
Main Bearing Journals
Diameter . . . . . . . . . . . . . . . . . . . . 71.361-71.387 mm, 2.8095-2.8105 in
Out-of-Round (Max) . . . . . . . . . . . 0.0254 mm, 0.001 in
Taper (Max) . . . . . . . . . . . . . . . . . 0.0254 mm, 0.001 in
Valves
Stem to guide clearance
* 0.001- 0.003 inch
* maximum allowable (rocking method) 0.017 inch
Guide Diameter (std) 0.313 - 0.314 inch
Intake
Exhaust
Face angle 43.25 - 43.75 degrees 43.25 - 43.75 degrees
Seat Angle 44.25 - 44.75 degrees 44.25 - 44.75 degrees
Seat Width 0.040-0.060" (1.016-1.524mm) 0.060-0.080" (1.524-2.032mm)
Head Diameter 1.88 inch (47.752mm) 1.617 inch (41.072 mm)
Length Overall 4.969 - 4.994 inch 4.978 - 5.012 inch
Stem diameter 0.311 - 0.312 inch 0.371 - 0.372
Valve Timing
see table
Valve Lift (zero lash)
0.410"
Push Rod Length
6.915-6.935" 175.64-176.15mm
Valve Springs
* Free length 1.967" 49.962mm
* Installed height 1.64" 41.66mm
* Spring Tension
o Valve closed 85 lbs @ 1.64"
o Valve open 200 lbs @ 1.212
* Number of Coils 6.8
* Wire Diameter 0.177" 4.50mm
