What is this junk?
Old Sep 25, 2005 | 07:59 PM
PARoadRunner's Avatar
PARoadRunner
Default What is this junk?
These alloy wheels have some kind of glue or cement on them on the center ring. 3 out of 4 of them have it, and it seems it was put there intentionally by whoever owned this car. I tried to wirebrush this crap off, but all that did was make the wheels look even worse, and busted up a perfectly good wire brush. Any idea what this is and how i might get it off?
Old Sep 25, 2005 | 09:28 PM
thump186's Avatar
thump186
Default RE: What is this junk?
looks to me as though someone broke the center caps and decided to glue them in.
Old Sep 26, 2005 | 12:22 AM
PARoadRunner
that would make sense, but why would someone put glue along the outside? When I wirebrushed a little section it killed the finish, it looks gross. I give up...
Old Sep 26, 2005 | 06:35 AM
Chump's Avatar
Chump
Kinda looks like some sort of double sided foam tape. Try getting some label adhesive remover from the auto parts store....some is citrus based and wont harn finishes. Also try an auto body paint supply store, they should have the correct stuff.
Old Sep 26, 2005 | 08:29 AM
PARoadRunner
this stuff isnt tape of any sort. Its definately some kind of cement and the little I was able to remove powdered off. I think what I need to do is get new center caps and somehow change these but I dont even know if that is possible.
Old Sep 26, 2005 | 02:49 PM
pembroke dude's Avatar
pembroke dude
The stuff you are seeing is corosion. This a common problem with plastic centers. The only fix is to replace them.
Old Sep 26, 2005 | 07:13 PM
PARoadRunner
The centers are metal...Still, Id like to replace them if possible.
