HELP!!! daytona
Old Oct 7, 2005 | 09:21 PM
daytonagirl's Avatar
daytonagirl
Default HELP!!! daytona
Does anyone have any ideas on why I keep blowing the ignition fuses? the car ran fine, it sat for a couple months, and now won't start. PLEASE HELP.
Old Oct 9, 2005 | 01:40 AM
Chump's Avatar
Chump
Default RE: HELP!!! daytona
Year and engine size? What is the fuse number that blows? Is the fuse underhood or inside car?
Old Oct 9, 2005 | 11:04 AM
daytonagirl
thank you, it has 3.0 engine 6 cylander, do't know the fuse # but it is under the hood, 3rd one from the left on the bottom row. hope that helps
Old Oct 9, 2005 | 04:15 PM
Chump's Avatar
Chump
I'm assuming it's a 1992?
Do either of these pics show the fuse that is blowing?
[IMG]local://upfiles/21718/256C21982557434491BE5D15C42082BD.jpg[/IMG]
[IMG]local://upfiles/21718/9700606D470047129115E0E6139FDACB.jpg[/IMG]
Old Oct 10, 2005 | 12:19 AM
daytonagirl
It's the bottom one image. yes, it's a 92. It's definatly fuse #51. i'm not sure about 52,53,55, some one took them out too.
Old Oct 10, 2005 | 01:12 AM
Chump's Avatar
Chump
ORIGINAL: daytonagirl
Good, no guarantees we'll get it fixed but we'll try.
Answer these questions and I will go over some wiring diagrams tonight.
1. With the key "OFF" does the fuse blow right away when you install a new one?
2. Does the fuse blow ONLY when you turn the key to "ON"?
3. Does the fuse blow ONLY when you turn the ket to "START"?
Old Oct 10, 2005 | 04:15 AM
daytonagirl
to start
Old Oct 11, 2005 | 07:37 AM
Chump's Avatar
Chump
Well, looked at the wiring diagrams and this fuse is really only used when the key is in the "on" position. So, could be a short in the ignition switch or it's wiring. Make double sure we are talking about fuse 51 and when you replace fuse 51 are you installing a 50 amp Maxi-fuse?
Most of my experience with blown Ign fuses turns out to be bad starters..but this appears to be a little different.[sm=bangbang.gif]
Old Oct 12, 2005 | 09:38 AM
daytonagirl
I'm sorry, It blows as soon as you put the key in . I was wondering if you could e'mail me a copy of the wiring diagram? peanutmommy5@msn.com. Thank you so much
