Changing plugs on 5.7 hemi
Old Nov 8, 2005 | 10:36 AM
larry2of5's Avatar
larry2of5
Default Changing plugs on 5.7 hemi
Any info on plugs to use, and can it be done at home? Shop is $$$$$ and thought id ask you guys/gals. Larry
Old Nov 8, 2005 | 10:48 AM
jasonwyo's Avatar
jasonwyo
Default RE: Changing plugs on 5.7 hemi
There are not many plugs available for the hemi that I have been able to find. Most likely best bet is to buy the mopar plugs and change them yourself. On my Durango, I have to take off most of the intake to gain access down the left side of the engine. With 2 plugs per cylinder you also have to take off the coil and the second plugs is located underneath of those. Its a good afternoon project to work on.
Old Nov 10, 2005 | 09:12 AM
thump186's Avatar
thump186
A couple I found all gapped at .45
another site.
http://shop.ignition-system.com/dodg...499&part_type=
autolite xp5263
regular champions
570
champion platinum
3570
champion double platinums
7570
champion iridiums
9403
Old Apr 30, 2008 | 03:30 PM
05ramhemi4x4's Avatar
05ramhemi4x4
DOes anyone no why dodge ran copper plugs ?
I thought copper was only for turbo or supecharged vechiles?
I was thinking about chaning plugs to champion 3570 in a 05 4x4 hemi.. Or do you think the stock copper plugs are best..?
Or should i 1stage colder if go with plaitum?
Old Jul 18, 2008 | 08:57 AM
BlueDodge's Avatar
BlueDodge
Everything I have read and heard says to stay with the Cu plugs. The 5.7 does not like platinum or iridiums. I was also told it helps to take the brake booster loss so you can get to the back plugs on that side.
