Speedometer not working after changing speed sensor
Old Nov 10, 2005 | 10:52 PM
Esmith8205's Avatar
Esmith8205
Default Speedometer not working after changing speed sensor
My speedometer is not working. I had a code p0500 and changed a sensor purchased at Advance Auto. Last year I had a code p0720 output sensor. I changed that sensor and it worked for a little while but broke again. Today i changed ABS or differentia sensor. Now there are no codes but my speedometer is not working. Any suggestions? Mabey a fuse or something? All other things on dash seem to work fine. tacometer is fine odometer obviously is not. Please help.
Thanks
Ed
Old Nov 11, 2005 | 01:43 AM
injmopar's Avatar
injmopar
Default RE: Speedometer not working after changing speed sensor
Have you checked the plastic gear in the speedo cable trans adapter. And is the adapter in the right clock position.
Old Nov 11, 2005 | 02:18 PM
Esmith8205's Avatar
Esmith8205
injmopar,
how do i check the speedometer cable trans adapter? Sorry, I am not a mechanic. Any info would be a great help.
thanks
Old Nov 16, 2005 | 01:41 AM
tenntech's Avatar
tenntech
What year, make, and model vehicle.
